compatibility between early style bayonet bulb holders and later bar style ?
    it was the cornering light, so not related to the blinker circuit. It was definitely a contact issue though since I could tap the fender and it would light up. The brass was corroded and causing contact issues.
      Crap, it is not fixed, just the China made blinker flashing two bulbs on the right and three on the left. At the same speed.
        good flasher then... still have the socket issue though. Sux
          I am guessing must be wires or multifunction switch as both sockets are now replaced.
          I would have preferred the flasher to not flash when a bulb is out, so I would know, but hey...
          I hate intermittent fails........
