Hi,
My fuel gauge has been defunct for some time. I am getting another cluster. I hope the gauge works. Never having taken these apart I have some questions.
1) Is it fairly easy and straightforward to change the indicated miles? I would like to set the "new" odo to the mileage of the original.
2) I found various discussions about drive gears but they talked about 90 & up. Should I change the 89 gears? Any source?
3) Is the rear end gear ratio relevant? If the "new" unit had a different rear ratio is there any change necessary in the cluster?
4) The new unit has a broken shifter clamp. If I can get mine out without breaking it, can I swap it in?
5) Should I install LEDS or just new incandescent bulbs? If so which ones? They will dim?
6) I guess the various gears are greased. Regular synthetic axle grease or silicone grease or ?
7) What else should I know, consider or expect to deal with?
Thanks,
Jay
Thanks,
Jay
