Here's the short story:
Working on the front passenger door window motor I believe I overloaded the circuits and caused some damage. I was pulling up on the window (stuck) and using both up switches, drivers and passengers, trying to get the window up (much longer story as to why). Passenger switch got hot and I felt a little shock.
Now my #6 fuse in the fuse box keeps popping when I turn on the ignition. I've replaced it 5 time now. I have disconnected both switches and the right front window motor, but the fuse still pops (short somewhere).
I think I may have damaged the Window Safety Relay (Chilton's Manual), but the manual doesn't tell me where it's located.
Where is the window relay located? Should I be looking anywhere else to see what I damaged to fix this?
