Door Flap Seal???
    Door Flap Seal???
    Not sure what this seal is called. It's not the door seal that goes around the entire door. It's the flat flappy type of seal that just goes around the top and front trim of the door to help keep out the rain. I have the front, but the top has rotted off and want to replace it. What is this seal called and where can I get some replacement seals? Thanks!
ID:	1300707Click image for larger version
    I'd rather be a failure at something I love than a success at something I hate.
    George Burns
    This may be what you need. LP 107-B/FT is the part number. look it up on this web site: http://www.metrommp.com/ Click on line catalog, then part type, then roof rail seals. You will need to contact cement this stuff onto the that trim. Also after you click part type look at door bottom seals and door top and side seals as they have some that you may like better.
    Pretty much research that site. They are great. They sell great replacement window channel moldings that fit out car.
      Wow there's a lot of seals on that site. It will take awhile to look through them all. Thanks for the site and part number! I'll be looking at the bottom seals too.
      George Burns
        Hey no problem.
