Filled the car all the way up yesterday and have driven about a hundred miles so far. The fuel gauge is pegged at FULL. Ideas? I know it's not spectacular fuel mileage, that's for certain!
'91 Colony Park fuell gauge
float might be stuck in the top of the tank. There may also be a loose wire, but I can't remember which wire being loose would make it peg.
Had this happen to me before on my old '91 colony park. Ended up hitting a huge dip in the road to free it up
If I recall correctly... yes, I do-- on the '91, and on the '90, which were opposite of the --89 models, "full" is also high resistance.
I agree that a stuck float is most likely.
But if the sensor wire became unplugged (easy to get to-- get the back of the car on some ramps and slide under with a flashlight!), it would also result in reading "full" all the time.
Or of course if at any point between the gauge and the sensor, there was a disconnect. But get under there, tap on the back of the tank where the sensor is installed, and at the same time just make sure the wire is plugged in there, not dropped off and hanging loose, and not overly corroded.
I checked what I could and things appear good. The gauge goes straight to "F" when the ignition is turned on. I'm thinking the sending unit went south, rather than a stuck float. Do I feel like pulling the tank to see? Not really. I'll have to see if the sending unit, or the float, is available before I even bother to pull the tank. If it's all a one piece fuel pump/sender/float, it's gonna read "F" forever.1986 Ford Country Squire LX 8-pass wagon 5.0L AOD
the float is available. The sending unit... not so much. Someone may have one squirreled away somewhere, but they're probably hoarding it for their own car.
