My negative battery cable was messed up so while I've been fucking around with everything lately I decided to replace it. Problem is (as usual) I'm fucking clueless. The cable that came off had three wires (refer to the picture below), the long large one (1) that was attached to something near the bottom front of the engine and the long smaller one (2) that was attached to the metal next to the radiator, and the small short one (3) that plugged into a socket of some sort.
The new one I ordered only has two wires, the long one (4) and the short one (5) which has nothing on it.
So... wtf do I do? I went to the parts store to see if they had one but they pulled out the exact same kind. Guy there said I'd have to splice the short small wire with the plug (3) to the short small wire on the the new cable (5). If that's the case then what about the second wire (2).
Thanks.
Thanks.
