ATC - a/c switches from recirc to fresh air randomly?
    resident HVAC experts - having a little trouble with my ATC I think. With the A/C on and about 85 degrees outside, I can hear the recirculation engage and disengage periodically. It will only engage for a few seconds and then disengage for a minute or two. Lever is on full cold and fan speed is on manual High...
    Any ideas? Thanks!
    1984 Mercury Colony Park Wagon - 393 Dart block LS 91mm turbo with 4L80E and 9" 6.24@115 in the 1/8 mile (9's in the 1/4), 4650lbs w driver, AC, Drag n Drive rig 1300hp
    1988 Lincoln Town Car - stock for now
    It should be on recirc all the time. If the thermal blower lockout under the hood is leaky though it won't be able to pull enough vacuum to stay in recirc mode. I've found that bearing balls make pretty effective plugs, though a golf tee or a screw dipped in silicone also works well.
      Ah yes - are you referring to that plastic fitting/valve in the heater hose? It was leaking and I just removed it...I don't remember any vacuum lines hooked up to it but I will look. Do you know offhand where these vacuum lines would come from? a specific spot through the firewall etc?
      Thanks!
        those two lines go back behind the engine. I'm not exactly sure where and I'm not sure if they're on the newer cars, but there's also a check valve back in there that is also attached to the vacuum reservoir on the driver inner fender that when it goes bad, does funky stuff with the vents.
          What are you hearing? A duct door open and close?
            Thanks!
            should have been 2 wires and 2 hoses. The wires you jump together, the hoses you plug off. They're the plastic tube type, one black and one blue. They should come out of a grommet almost dead center of the firewall, a bit below the vacuum tree. I forget which is which, but one is tee'd into the source vacuum for the ATC, the other is tee'd into the line to the recirc door. Either one being open would make the system act stupid, though having the source one open makes it massively stupid. It goes to hot defrost whenever you touch the throttle, etc.
              I am hearing the door for the recirc open and close...I will check the vacuum lines for the heater hose thing (TBL) as soon as I have the wagon back...I think that must be it since I just took it out...unfortunately I don't remember there being vacuum hoses connected to it
