Does anyone have a pic of what the AC WOT relay looks like and where it is located? I "think" it's supposed to be on the passenger side fender? I have the EVTM for my 1984 wagon - can I assume the wire colors lsited are correct? I have a suspicion that this relay was somehow eliminated by accident during my CFI/SEFI HO swap.
My A/C doesn't work, I have over 70 psi static pressure in the system, low pressure swith is fine, I can put power directly to the compressor and it runs, and there is no voltage at the compressor coil plug with the a/c switch engaged.
The only other piece of the puzzle is the WOT switch right? And the ECM of course but I know that wiring lined up for the most part - are there any mismatches from the SEFI cars to the CFI cars in terms of the A/C EEC wires?
Thanks for the help!!
