Window motor or window regulator replacement
    The bolts hold the motor to the regulator. The regulator is held in by multiple rivets. Even if you wanted to remove the regulator, IIRC, the motor has to come off anyway. Because, I cant remember if the motor fits through where the glass runs.
      Unless thee is something wrong with the regulator don't bother trying to remove it.
      .....have to sign in to see that link you posted....
        1/4"x20 nuts work well in place of the bushings. stack 2 on top of each other and you're good. Easily found at your hardware store for like pennies. You need 6 per motor.
          Thanks to you all for the great information. Hope to return the favor someday.
          bob
            You All were SO RIGHT--------------------Motor came out huge speaker hole, opened up it just had white mush and pieces.
            Thank-you..........................
              Smear some paint or grease where you drilled the holes to prevent rust.
