Yesterday the blinkers on 86 gm stopped for good. what could it be? Is it a turn signal switch itself?
No turn signals.
Check the turn signal flasher. It's the big round thing in the fuse box under the I/P. I used to have non-functioning turn signals or ones that blinked superfast and it was the flasher that went bad.
Do they light up but just not blink? This happens when a turn signal bulb is burnt out. Often one of the two in the rear burns out and you can't tell.
flasher probably went south
They dont blink at all (dont light up) I tried a baxters one and right one went on blinking and didnt want to turn off.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Seriously guys can any body pinpoint to me where the problem is? Its not the switch nor flashers (i replaced both now they dont stop).“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Just have to ask. Is the 4 way switch engaged?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostJust have to ask. Is the 4 way switch engaged?
The hazards are working normally. I just removed the flashers (cause new ones wont turn off) and drive without them but would like to fix the problem so the pigs wouldn't bother me.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
So with both flashers in and the 4way switch pushed in, you have 4 way flashers on all the time?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
If you pull out the 4way flasher and leave in the turn flasher, what happens?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
if the 4-ways are on all the time with the flasher in, then the blinkers will never work since the 4-ways are switched on. You need to fix that before the blinkers will work.
Originally posted by jaywish View PostIf you pull out the 4way flasher and leave in the turn flasher, what happens?Last edited by 90ltd; 02-15-2013, 09:35 PM.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
