Relay
    Relay
    Is there a relay on a 1990 grand marquis for the fuel pump because if there is I can not find it.
    should be on the driver inner fender.
      It's labeled fuel pump too isn't it?
        driver inner fender, should be labeled, it's in a plastic housing
          I see a black box but it is glue sealed or something because it will not open
            Pull up on the section with all the wires. This part comes away from the rest of the box. Then there's a clip that releases the relay box from the little section.
              I toke off that little box off the big box but still do not see a clip
                Its on the end opposite where the wires come out. Push down on the tab, and slide the outer cover off.
                  Which one is for the fuel pump?
                    The cover is marked with the positions of what relay is which.
                      Mine is the middle one. I have a 97.
                      1997 MGM (bought for a song) MODS: New 70mm MAF, True Duals w/ GlassPacks, 70mm TB, Full custom CAI w/ Cone Filter, SCT tune, Marauder 21mm rear sway, Moog end links, 29mm CVPI front sway, Trak Loc posi w/ 3:55's.
                      On The List: JMod, PI Intake, Ported Plenum, TB spacer (maybe) Fatter Tires for summer, HD Cop Shocks, Rims, and hopefully new green skin.
