Hi,I have a 1985 Mercury Grandmarquis with the CFI 302.When I first start it,it runs good for for about 6 or 7 minutes,then it will start to gradually start to run really crappy and stall about 3 or 4 minutes later.It usually won't start after it stalls.After sitting for a few hours it will start and do the same thing again.
So far I tried swapping out the throttle body with one I had from the junkyard.It ran the same with the junkyard throttle body,so I put new fuel injectors in my original throttle body(thinking the injectors were the problem)and put it back on the Merc and it does the same thing.I also swapped out my TFI ignition module and the coil,with one from a "84" Lincoln and that didn't help either.Also It has new spark plugs and wires.
Any advice will appreciated![:-)](https://www.grandmarq.net/vb/core/images/smilies/smile.gif)
Thanks
Thanks
