I was working on replacing my heater core, here is the forum for that problem:
http://www.grandmarq.net/vb/showthre...er-Core-No-Hot
I took apart the dash to include removing the cluster panel. I started the car off and on while fixing the vent doors in the plenum. I had the car doors open for long periods while working on the heater core and dash. Well I noticed that the windows were getting slower going up and down from the dome lights burning. So I ran the car for awhile so the alternator would recharge the battery. It got worse. I pulled out the volt meter and its only charging at 11.5 and dropping.
So today I replaced the old alternator (life time warranty) with a new one. They did not check the old one to see if it was working, They took my word that it was only charging at 11 volts. I put a charger on the battery while I went to O'Reillys.
I put the new alternator in and the same thing. Now its 11.77 volts and dropping. When I 1st did the 3G upgrade it was around 14 volts.
So I know I did something. Does the dash cluster panel need to be installed to complete a circuit? (Its still off). Is there something under the dash I might have disconnected by mistake causing this?
Other than the no charging, the car runs fine. I had arched things in the past with my truck and it was always the distributor module I would fry. I would think that would have fried before the alternator.
Any help would be appreciated!
(Called the parts store for them to test the old alternator, they'll get back later with the results)
