Engine ground wire?
    Engine ground wire?
    Where exactly is the engine ground wire located? I am talking about the one underneath car.
    near the passenger side engine mount. in front of it iirc.
      right behind the smog pump if that's still in there.
        what is the iirc?
          oddly the smog pump is not there.
            sorry IIRC is "if I recall correctly". Internet slang/shorthand. Search for a wire going to the front lower passenger side of the block and that should be it. If it's not there, you should at least find a bolt or bolt hole not doing anything on the side of the block in that area, which would be where the ground strap SHOULD be.
