Wet to the junkyard and grabbed a tv lever from a 91 GM. It was like the one 85CrownHPP has. It works great. The selector lever on the 90-91 cable driven cars is taller like my car's so the tv lever fits perfectly. It shifts now and all is good. It seems to shift a bit later than it used to though and sometimes the transmission seems to hold the car back when I'm off the gas.
Can the tv cable be adjusted like the tv rod can? I'm shifting to second at about 18-20 used to be around 15-18.
Also anyone know what this connector goes to, it's connected to the ECM harness near the waterneck and goes over near the alternator or ac compressor.
![Click image for larger version
I also got the speed hooked up and now I only need the oxygen sensors, and an airbox.
I still only get the codes for the neutral safety and the canister purge solenoid.
