I did not wire in the red/blue start wire at the connector in the picture, only at the wiring near the trans dipstick. I had the swap running before I ever did that though...
Do you hear the fuel pump turn on? got fuel pressure? If you only added 'run' directly to the EEC relay, you probably aren't getting power to the fuel pump relay. You could either try splicing the pin you pulled out of the EEC relay into the 'run' wire you put in it and see if that gets it to everything else, or try making the 'run' splice in the connector where I did (or whatever equivalent you have for your older style harness)
