Okay, here's the story so far.
Fuel pump quit in the Vic wagon. Dropped the tank, changed the pump (Also the FP relay and fuel filter) started up and it ran fine for 2 days.
This morning, no FP noise and no start.
Dropped the tank out, made up a new plug for the harness where it meets the fuel pump and the pump works. Car started and then quit.
Got messing around under the hood and pulled the old hood lock/fuel pump?/ ignition cutoff? security system the car had on it when I bought it and spliced the wires back together. car started and ran.
Soooo tank back in (had just dropped it a bit with the jack) started up and was coming back down off the ramps when it quit.
Same as before, crank but no start. No power to the inertia switch, or fuel pump.
Only thing left we haven't changed out is the actual wire between the front and the back of the car...
Any thing else you can think of that I've missed?
