if you're car is NOT equipped with cornering lights... check the wire harnesses above the E-brake. Mine were crushed by the e-brake lever and kept blowing the fuse in my 88 which also had the feed for the fuel gauge.
Other than that... check all that crap listed on #6. PITA, but that's about the only way.
