I just had this issue present itself while driving home. I had the brights on while going down a poorly lit back road when they went out. Not just the brights, but all the headlights were knocked out. The car was still running, the parking lights were still on, but just the headlights went out. Then they started to flicker on and off in quick sucession, went out again, and finally came back on. I shut off the brights and put on the hazards for the rest of the trip home in case it happened again. Question is what could it be? I have no clue how to work on electrical so I don't know how to diagnose this kind of problem if it's something other than a bad fuse.
Brights flickering
the headlamp switch has a circuit breaker built into it....if it gets too hot,it will shut off power to the headlamps to prevent an electrical fire in the wiring......after years of use,these thing break down and become "weak"...also check for a "melty" looking connector were the wiring hooks to the headlamp switch....this tends to happen to these cars also when this happens......my guess is you will need to replace the headlamp switch (not actually being there to look at the car,this is an "educated" guess.....it is also possible that you may have other issues,but id check the headlamp switch first)
ditto03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
X3. I would also try wiggling the big connector on the drivers side fender towards the front of the car, see if they flicker. Big white half moon sucker.
All front lights run through it.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
If you have to go the route of replacing the switch (it's rather a PITA to change), I would definitely consider the headlight relay mod to reduce the draw on that circuit breaker.
Originally posted by Piece-it pete View PostX3. I would also try wiggling the big connector on the drivers side fender towards the front of the car, see if they flicker. Big white half moon sucker.
Pete1985 Mercury Grand Marquis "Shelley"
-- Donated and gone to auction
Originally posted by slymer View PostIf you have to go the route of replacing the switch (it's rather a PITA to change), I would definitely consider the headlight relay mod to reduce the draw on that circuit breaker.1985 Mercury Grand Marquis "Shelley"
You would purchase a normal replacement switch. The relay mod he is talking about consists of adding in relays to power the headlights so the entire load is not carried through the headlight switch itself. It is usually preformed to prolong the life of the headlight switch while actually allowing more voltage to reach your headlights resulting in brighter lights altogether.~David~
The reason the light switch gets hot in the first place is all of the current going through it, the headlights draw their power from the battery via the switch.sigpic
More voltage would result in somewhat shorter lamp life. That is the tradeoff for brighter lights.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
running the wires and relays for the mod though can be a pain too... but if you check out the "cheater's method" that I used on my 88 (in my readers rides thread somewhere... link in my signature), you'll see that the only wire I ran was the new power wire from the battery to the relays and just spliced them into the mess on the driver inner fender.
Same here. Easy. Cheap. Huge difference.
The plug I mentioned is right near the regulator, a silver square box screwed to the fender. Iirc the plug has 8 wires in/out.
It doesn't really shorten the lamp life significantly. They are designed to run on about 14 volts, which is what you get with a relay harness. With my car, before I put in the relays I was getting not quite 12 volts, 11.8 or so at the lamps. With the relays, I get just over 14, roughly 2.5 volts difference. Even with very old headlights, the difference was quite impressive. I ran those old headlights another 3 years until I had the car painted. I haven't got a clue how old the low beams were, but the high beams were original 1986 lamps and still working when removed in 2011. I know that I did not put those low beams in the car though, and I've owned it since 2004, so they were at least 7 years old when I took them out.86 Lincoln Town Car (Galactica).
