i am only going to use motorcraft remans from now on........the new ones are crap and the other brand remans do not seem to hold up.........the price from ford is not much higher than a new made in china compressor.
Best AC compressor to buy
Originally posted by gadget73 View Posth8 you R12 people. Mine gets down to 40-42 driving, and goes up to nearly 60 at a stop. Stupid enviro-friendly nonsense refrigerant.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Underdrive pullies do not make for good idle speed AC performance. Its not just the R134, at least some of it is the pullies. Less airflow plus less compressor action really makes it suck. It would go up with R12 under those conditions too, though probably not quite so much. I'm gonna try fitting a pusher fan to see if I can get some improvement from it, and I'm also going to look at later model native R134a cars to see if their more efficient condensors can be easily retrofitted into my car.86 Lincoln Town Car (Galactica).
I've always liked Seltec-Valeo compressors, especially the HT6 knock-offs that they make. Quality seals internal.95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
96 Buick Roadmaster Limited Wagon, mostly stock
77 Ford F150, 400M auto, longbed
98 Suburban LS 5.7L Vortec, stock
90 Grand Marquis, stock
R12 is out there...I was amazed how much of it popped up on craigslist during a few weeks of searching...I struggled with 134a conversions for the last couple of years...r12 condensers are too small, 134a does not keep vent temps at idle as well...for example I dropped my vent thermometer into a brand new 2012 buick we have as a company vehicle...of course 134a but designed for it...vent temps never got below low 40"s (i imagine by design) and sitting at a light, right at 50 degrees. Brand new car, electric fans etc....it was over 100 outside but my wagon has no problem getting down to 37 or so at 110 degrees outside...44 or so at stoplights.
For a 134a conversion, gadget's numbers seem pretty good to me depending on the ambient temps...1984 Mercury Colony Park Wagon - 393 Dart block LS 91mm turbo with 4L80E and 9" 6.24@115 in the 1/8 mile (9's in the 1/4), 4650lbs w driver, AC, Drag n Drive rig 1300hp
1988 Lincoln Town Car - stock for now
yeah... best bets are to swap out the condenser as well when doing the 134a conversion... but that's a PITA on most vehicles.
Originally posted by drhill View PostR12 is out there...I was amazed how much of it popped up on craigslist during a few weeks of searching...I struggled with 134a conversions for the last couple of years...r12 condensers are too small, 134a does not keep vent temps at idle as well...for example I dropped my vent thermometer into a brand new 2012 buick we have as a company vehicle...of course 134a but designed for it...vent temps never got below low 40"s (i imagine by design) and sitting at a light, right at 50 degrees. Brand new car, electric fans etc....it was over 100 outside but my wagon has no problem getting down to 37 or so at 110 degrees outside...44 or so at stoplights.
For a 134a conversion, gadget's numbers seem pretty good to me depending on the ambient temps...95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
