What GM HEI distributor reference I can ride? There are several models.
Ignition problem
this is one of the hei ones made for fords
You need one wire that is hot in both key-on and with the engine cranking. See what they tapped the fuel pump from and see if that will do the job.
Oh, make sure what material the distributor gear is. It needs to be iron on your engine if its an 84. If its an 86+ engine, it needs to be steel.86 Lincoln Town Car (Galactica).
Not sure what you are asking for. Do you need the ignition firing order, or something else? Also, which distributor did you buy?86 Lincoln Town Car (Galactica).
I bought this HEI distributor, http://compare.ebay.com/like/3706017...Types&var=sbar.
I need what is the ignition diagram for switch on the car, that is, I need adjust the ignition in his point.
