for the 86 sd 5.0 where are the grounds located for the computer contolls/ sensor wiring. is it on the fire wall?
wiring harness ground location
1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbinesTags: None
Its the tiny wire on the negative battery terminal. Follow it back a bit and you should find a connector that likes to corrode.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
there are two actually. One at the battery, and one at the rear of the intake manifold. I believe that one is an orange wire, and it often breaks off.86 Lincoln Town Car (Galactica).
