Since i dont need the tickets i need to fix this. When i press the turning signal the indicator light will come on but wont flash same with the actual turning signal on the outside of the car. At first only the left turning signal did this but now they both do. When i use the hazards both turning signals come on and both flash so i dont know whats going. Any help would be nice.
turning signals wont flash
Im pretty sure your problem is the turn signal relay (if Im thinking of the right name for it). Its the thing that makes them blink. I attached a pic of what Im talking about below. Its a round, metallic gizmo that sticks out in the fuse panel, just swap it out for a new one and it should fix your problem. When I bought my '87 it had the same quirky turn signals, swapped that relay and they've been fine ever since.
-2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
-1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
before you look at the flasher, make sure you dont have any light bulbs burnt out. having a burnt out bulb, lowers the circuit load and wont trigger the signal flasher. usally stop/tail light bulbs are the first to go.
Yeah i've been faked out by only one of the two lights that flash in each tail light being burnt out. This can make your blinker not flash. Both bulbs in each tail light should flash. Visually confirm with the bulbs removed from lenses if need be.
Originally posted by 351PoliceVic View PostSince i dont need the tickets i need to fix this. When i press the turning signal the indicator light will come on but wont flash same with the actual turning signal on the outside of the car. At first only the left turning signal did this but now they both do. When i use the hazards both turning signals come on and both flash so i dont know whats going. Any help would be nice.
I was told that if the flasher is bad, then nothing will flash. I don't know if that's correct or not.Last edited by TomO; 02-25-2012, 08:51 PM.
Originally posted by 351PoliceVic View PostI did have a bulb out so i went head and replaced all four and i checked and they all worked. Tomorrow ill replace the relay tomorrow and if that doesnt work ill replace the switch. How bad is it to tear into the steering wheel and replace the switch?
My vague recollection is that the hardest part is unplugging/plugging the wiring harness from/to the switch because it's really tight.
There are two flasher units on these, so most likely the standard one has given out. The hazard one never goes bad because its almost never used.86 Lincoln Town Car (Galactica).
When my flasher went bad, it simply stayed off, nothing on the dash either (and the dash arrow is part of the same circuit).
If the dash light is working, then the flasher is probably working.
If the dash light is blinking really fast, it's a burnt bulb, as someone already said. Lower resistance means more current flow, which means the bimetallic strip in the flasher heats up faster, so it blinks faster (when the strip heats up, it curls, breaking the circuit. Lights go off. It cools and straightens, completing the circuit, lights go on, heats up again, and repeat. And thus the lights flash on and off and on and off).
Flasher is like $8 and right by your left knee, the round thingy in that fuse panel.
If it's neither of those symptoms, and you find it's the multifunction switch, I believe any basic handyman set will do you ; little 1/4" ratchet and socket set, and phillips screwdriver. I don't think there's any part of the instrument cluster or dash trim that needs to be removed; just lower/pull out the steering column for the most space.
I paid $30 for my switch; you can even find NOS switches on ebay for that price. I got an aftermarket from amazon that is just fine. Actually, my switch I replaced in pursuit of perfection because the cancel cam was getting a little weak, but it's still good if you want it for $5 to cover shipping...
If it turns out there's trim that is held on by the ignition switch --I can't remember-- then that's easy, too, actually. There's a hole that looks like it should be a screw hole, but there's no screw in there, just a release button. Put the key into position II? Or position I? Use a smaller screwdriver to press up into the hole and onto the release button, and pull out on the ignition switch, it'll come right out. Don't play with it and let the two halves of the ignition cylinder separate; there are a couple balls or rollers or whatever (you can tell I'm not a locksmith!) that will fall out and then you have to figure out where they went
Err, you might not have to remove the ignition switch at all. I can't remember and am just covering all the bases!
yes, that's a bad flasher unit/ relay. It's stuck on; the bimetallic coil isn't clicking off and on like it should.
I'm surprised the right hand signals still blink though.Last edited by BerniniCaCO3; 02-27-2012, 12:53 AM.
