Can you adjust the box headlights?? or am I missing something I think I found the adjusting screws but im not sure cause they didnt do shit Haha
Adjusting Headlights??
yessigpic
A cordless drill might be an easy way to round them out... they should not need more than a few turns to adjust unless they have broken or popped out. Sometimes they just freeze up and wont budge, then just replace them. Also make sure the spring is still in the corner of each bucket.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
remove them 1st and see if they are frozen or broken, 2 for each headlight, you can get replacements most anywherePete ::::>>> resident LED addict and CFI defector LED bulb replacements
http://www.coolbulbs.com/HID-VISUAL-...-PROCEDURE.pdf How to aim headlightsWARNING: Above advise is based on actual experience or just plain common sense. In the event said advise is determined to be incorrect you are entitled to a full refund of exactly what you paid for it.lol
85 LTD Crown Vic Coupe 302 CFI Dual Exhaust No Cats Thrush Welds
pwr windows, locks, seat, antenna
cruise, tilt, white on white, maroon interior
and I'm usually only 5-6 feet away from the wall. everything else is sloped.
