So I have the dash/running lights not working (intermittent, actually) issue on my 89 GM. I reached up into the dash behind the switch and basically wiggled shit around while doing same from front of swich, and was able to get running lights back on. Then they were off - then I did the same and got them back on.
I'm assuming from threads I've read (and a suggestion made to me when they were just intermittent) that the harness needs replacing.
Can someone point me in the direction of where to get one, and what's involved with replacing it? Is it done from under the dash (ouch, my back) or through the dash after trim removal?
Brad
Brad
