Quick question, I had an 85' GM that had shitty heat so my brother did a heater core, didn't fix it. So I fumbled under the dash, but my finger over a hole on a blue sensor, and voila, hot smoldering heat, so for the winter, I just stuck a piece of foam in it and called it good.
So I have an 87 GM that has similar issues to this. I flushed the system, still just mediocre heat. I want to take the dash apart and test the sensor but I have a quick question.
Is this sensor in all the Grand Marquis, or just the ones with the auotmatic climate control? My 85GM had Automatic Climate and this one doesn't, and I don't want to dig around the dash looking for something that may not even exist. Gonna check the blend door while I'm in there too. I don't really want to spend the money on a new sensor that is like $80, but if it means hot heat in the shitty Michigan winters, spare no expense.
