front speaker harness disconnect question....
    Just got some new 4-way Pioneer speakers to replace the blown out ones in the Grand Marquis. I'd like to solder in the wires. I know there are connectors right at the speaker itself, but is there also another disconnect up inside the door that I could reach?? I'd love to solder these in instead of crimp connect.
    Thanks for any help...
    95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
    96 Buick Roadmaster Limited Wagon, mostly stock
    77 Ford F150, 400M auto, longbed
    98 Suburban LS 5.7L Vortec, stock
    90 Grand Marquis, stock
    They sell nice connectors that you can solder onto the speaker and then plug right into the factory plug (no cutting the factory wires). Crutchfield has them and quite possibly your local Best Buy may have them if they have an install shop at the location.
    I don't believe there is another disconnect up inside the door.
    Past Panthers
      I would just use the connectors that plug into the Factory wiring. Easy and they do stay put!
        the speaker adapters at crutchfield FTW. have those on all of my cars.
          nothing inside the door. There is a connection under that side kickpanel usually, but its buried among the 400 other things right there. You really don't want to have to meddle with that unless you have no choice in the matter.
            I connected the speaker adapter to the dash harness and extended the wires into the door with the wires that came with the speakers. A little solder and heat shrink is all it needed.
            at least in my 88. The mark has 6 speakers.
