3G conversion.
    3G conversion.
    Sorry for dumb questions. Where to get a megafuse for 3G conversion? Do fatter wires have to be installed?
    “Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
    Fatter charge wire is highly recommended. 3 g alternator uses a charge stud whereas the old 2g had the spade connections. Check out ebay and type in mega fuse. plenty of cheap options come up. Or you can visit your local auto wreckers/junkyard and pick one up easily from any vehicle with a 3g alternator. Easy way to make the connection is to put one side of the fuse on the battery or starter solenoid while bolting the charge cable to the other side. Mega fuse holders are also sold if you want to go that route. Either way works.
      parts stores will have megafuses for like $5-$8. Just use a short 1/4-20 bolt & nut to fasten your wire to the fuse.
      I made my own charge wire: 4-6gauge THHN wire from home depot, at like $1.xx/ft, and then two ring terminals. Guess it cost $10 then.
        You can find 130-amp charge wires with fuse links on other fords in the junkyard, thats what I use. Its hard to find ones long enough to reach, even more so to find ones you can tuck away nice.
        Most Taurus 3G donors have a nice long 2-piece charge wire and a mega-fuse you can harvest, if you feel like extracting and dissecting a semi-buried wire harness.
          The bonus to stealing the cable from a car is that its finer stranded, so more flexible than Home Depot wiring. Fancy stereo wire works nicely though.
            welder cable works well too (it's of the finer stranded variety)
              My charge wire for this job is a Windstar charge cable. It is up high and easy to cut out of the harness.
                I used a charge cable from the Taurus I originally pulled the doa 3g from.
                  This is what I did.
                  1988 Signature Series Town Car
                    I found a charge wire from a late 90's E series van. harness and alternator were laying in the back of the van, I got both for $10 at the pull a part.
