Headlight Low beam issues...
    Hi all, glad I stumbled onto this site. Im hoping someone has seen this issue with there car. I have a 1991 Grand Marquis (5.0 blue), went to turn the headlights on the other night and all I got on the low beam setting was parking lights and tail lights. No low beam head lights. High beams however work. I checked fuses, replaced both low beam lights thinking a coincidence happened and both bulbs burn't out, but that was not the case. So now I am sitting with a car with no low beams, but high beams. Is there a relay that could be failing? Has anyone seen this before? Thanks in advance for the replies, Corey
    There are no relays, so that is not your problem.
    With the headlight switch pulled out entirely and when you pull the high beam lever do the low beams light up then like they normally would?
    For a circumstance like yours (both going at the same time) my guess would have to be the headlight switch.
      I would go more with the high beam lever. Mine did the same thing untill I replaced the high beam lever. Then I did the relay thing and all is fine.
        Sounds like the multifunction switch in the column. The headlight switch puts power to the column switch, and that switch will connect either to the wires feeding to the low beams or high beams. Either that, or its a connection between the headlights and the dash. Not sure if the 91 has this, but I know the 80s models had a big connector on the driver's side fender, a little behind the wash bottle that had a ton of wiring in it. Some of the wiring in there fed the headlights, and occasionally the connector would get crusty and the lights end up dying. Usually its somewhat obvious because when you look at the connector, it will have a melted spot in it. See if you see anything like that. if the connector is damaged, usually the fix is to cut the damaged wire right at the connector and bypass the plug.
          If I pull the hig beam lever, The high beams are on, and the low beams are faintly on. I think this issue will be a trial and error issue. Not sure which one to start with first the headlight switch or the multifunction one in the column. Is the column one a big job?
            Column one would be WAY easier.
