Hey--
Retested my fuel sending unit tonight.
The hot coming from the fuel gauge DEFINITELY reads 8.04V STEADY. I tried setting my multimeter to "min/max" which takes a voltage range over 100ms of time. Nope, nothing, nada, just 8.04V steady. Granted I've never used that function before, so I might be doin it wrong; but it seems pretty self explanatory.
This hot is supplied from a voltage regulator that is supposed to put out a pulse width modulated 5V average.
Is 8.04V flat cause for concern and possible replacement of this regulator?
It's like a $30 part. Dunno how hard to get to.
I also did retry grounding out the hot, thereby simulating 0 ohms resistance. As 8ohms=full tank, the gauge needle should have swung to the far right, and it did not move a bit.
Granted, before I grounded out the hot, I had simulated infinite resistance, which -maybe- should have shown a super empty tank? Then again, maybe not, because 86ohms resistance (=empty tank) at least has some electricity flowing to move the needle with.
Not sure if this means a new gauge, which, would mean a new instrument cluster, from some where??
Or if it could still possibly be the sending unit?
I'd like to know why grounding the hot didn't do anything, and I'd like to know of that 8.04V is a problem requiring a voltage regulator.
