Originally posted by GM_Guy
View Post
parking brake light?
Thats the way it is. Its is more of a your brake line sprung a leak warning. And in some cases, you need to put quite a bit of push into the pedal for it to come on. In theory only, it should reduce the flow of brake fluid out of the sprung line when the piston gets shoved to the low pressure side.
Alex.
All the more reason to replace that little disaster with appropriate aftermarket valves from Speedway Motors! 2cents: I only hope the '90-up system is a bit more reliable.
I will say, though, that driving a RWD car in snow with NO rear brakes is quite an experience!2012 Mazda5 Touring | Finally working on the LTD again!
They also have this neat mini prop valve (I already had the SS Brakes one I used, which is similar to the Wilwood above): http://www.speedwaymotors.com/Compac...alve,1979.html
But if your stuff is working OK, I wouldn't bother.Last edited by 1987cp; 09-22-2011, 07:31 AM.2012 Mazda5 Touring | Finally working on the LTD again!
