i've read some info about this mode of trip computer, but didn't know how to activate it and how run tests for this device. please help me if you can.
tripminder selftesting mode
Press the E/M button and the Time button at the same time.
Press the E/M button a few times and tell us what you see. Should see NTM 3 or something like that and some other stuff involving 8s and 7s. Or if it's NTM 2 it's something else.
Time button goes through the counter display 1111-2222-3333-4444-5555-6666-7777-8888-9999
The button next to time shows distance traveled, as you're driving it should go from 0-25.5 iirc.
Econ does fuel flow, as you're driving it should go up from 0-25.5 also iirc.
The last button shows the dim feature, turn on the headlights and turn the knob to adjust the brightness of the lights, the numbers on the tripminder should change in response to you changing the brightness of the lights.
Pressing the set button also makes it say something also.
To leave test hit reset.
