Ok man you come to the right place for CFI help! Check the connector that plugs into teh TPS and make sure the wires are not lose also even if you have to splice a new connector in do so b/c these connectors seem to just crumble and fall apart. Also check teh connectors at the the two injectors if the tabs are broken replace the connector because the bouce up and down and cause teh car to sput. Also check the main black connector for both injectors in sits right below the CFI housing if its not tight it will bouce around also. Once you check all that and if you are still having problems just hit me up on here or aim and i can walk you thru all teh steps i did to stop my stalling problem with my CFI and everything i checked.
My car is Possessed!! Please help!!! IF YOU CAN
the CFI on my '84 is just driving me nuts with it having an intermittent engine miss.... you drive it for a while, and it will start missing when your sitting at a red light.... Then at the next light, it will run fine.... we have changed the plugs, wires, distributor cap and rotor button, found one loose wire where the idiot that had it before me tried to splice the wire on the TPS... with TAPE... and twisted together... if you shook the wire the car would quit! My mechanic was taking the air cleaner off.. and the car quit... he looked over a me and said, "I've never had THAT happen!" So we thought we had it fixed.. as it ran fine after that... until I stopped at the first red light on the way home.... started missing like there was ONE sparkplug wire or plug messing up... but you put it in the scope... everyone is firing fine... So any ides on THAT??? Tom!!!
Originally posted by Grand_Marquis_GTTime to drop a 4bbl on that sucka
Of course, use a Holley "Low Rider" carb
Originally posted by ChachiOriginally posted by Grand_Marquis_GTTime to drop a 4bbl on that sucka
Of course, use a Holley "Low Rider" carb1983 Grand Marquis 2Dr Sedan "Mercules"
Ok, i started it up and started tapin harnesses, and relays but i could not get it to stall. then i unpluged harnesses and pluged them back in still no stalling. but this time when the engine got up to temp it would not maintain a smooth idle, nor would it stay running if i let off the throttle. then i unpluged the harness going to the egr valve and the idle smoothed out but still no stalling... this is driving me nuts
Clogged EGR will def make it stall and run like shit. Pull the whole CFI unit and take the spacer plate off, then clean it real good. Just pulling the valve usually isn't enough to keep it running right.86 Lincoln Town Car (Galactica).
