I bought my Grandmothers 88 GM LS. My grandfather bought it new in 88. I brought it across the provincial/state boarder from Alberta to Saskatchewan and had to get it inspected before I could plate it. It was mostly all good except it needs a rear brake job, and the guy said that the signal is "too slow" between ticks. It DOES signal fairly slow, but when I mentioned it to my father and my uncles (who have been around the car since new) they stated that it has ALWAYS been slow signaling. So I cant get it plated until i fix this supposed fault thats been there since the factory.
Before I fix this, I just wanted to see if ALL Grand Marquis have a lazy signal speed, or if the car was faulty from the factory. I also was wondering if its likely the signal relay/switch thingy in the fuse box that needs changing?
Thanks
Thanks
