Electrical "gremlin" in my 91,,,
    OK, my 1991 is doing stupid things when cold....(Well, as cold as it can get in 100 degree heat!)
    When I first start the car, and go to drive it, for about the first 3-4 blocks, it is intermittently not charging. it will stop charging for about 5 seconds, the battery light will come on, then start charging, the battery light will go off, and be fine for about a block or so, then it does it again... once I drive about 5 blocks, it will not do it again. Like it heats up, then it is fine? Sort of hard to trouble shoot! It almost acts like a main circuit breaker is getting weak and intermittenly kicking out... Maybe there is a big breaker in the underhood box I should look at? Other possibilities I am looking at is maybe a bad battery cable, voltage regulator, or alternator?
    I thought maybe someone here had the same problem and solved it, saving me some time. It only does this after sitting longer than 8 hours... (It never really gets "cool" here due to the 100 degree heat right now!) after it has been run, it never does it again, until it sits for at least 8 hours...
    Tom
    Stock or 3G alternator?
      100 amp with external regulator, ala copcar!!!
        1G !!!
        check the connections to the external regulator as well as the charge stud and battery. might be corrosion. The alt may also just need brushes.
          Well, before i could figure out what was causing the problem, it quit doing it.... So now I can't diagnose it! I will probably put all the new parts in it anyway, just to make sure....
            I would still double check all the regulator connections. also check all the grounds, mainly the battery ground cable that goes to the block.
