So ....... what happened to the alternator? Only thing I know of a "murdered" alternator was one that randomly shorted out its rectifier whilst installed and operating correctly, and never bothered to tell me why.
Top terminal to side terminal change over problems
Originally posted by 1987cp View PostSo ....... what happened to the alternator? Only thing I know of a "murdered" alternator was one that randomly shorted out its rectifier whilst installed and operating correctly, and never bothered to tell me why.
Originally posted by 84GrandMarquis View PostWell I say murdered since apparently my good old brother and dad so kindly "helped" by hooking up the battery.... Backwards,...
I would expect to find other cooked wiring and/or components down the road as a result of this.
When I originally mentioned spiking the alternator I was making reference to the often deadly voltage spike which results when you remove a cable from the battery with the engine running and then hook it back up. The old externally regulated Ford alternators were pretty resistance to damage so many people were in the habit of checking alternator function by pulling a cable and seeing if the engine stayed running. If it did, the alternator was working.
These days people kill alternators while "jumping" a battery to start another vehicle with their vehicle running. You should always have your car off when you initially hook up cables to the dead battery and then attach the ground cable last and remove it first once the other vehicle is running. If the other vehicle has a dead alternator you can cause a spike when you remove the cable with your car running because there is still a high draw.
I remember checking the alternator that way, didn't know it changed, thanks.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
side terminal batterys fuckin suck..
carry onGive a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
Originally posted by cld783 View Postside terminal batterys fuckin suck..
carry on
Boosting them is miserable. But like ya said, freebie.sigpic
Its definitely more cumbersome and precarious, but I have cables with swing out clips for side terminals for mine . Regular cables do like to slip off though, making a possibly aggravating situation even more so...!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Update: Well the alternator is fixed, plain old 1G rebuilt motorcraft. Things appeared great, but I noticed that when ever it rains the amp light comes on... I thought mabye the ground was getting wet but then wouldn't that completly kill the car? Mabye, I don't really know, I'm just surmising since the point of the ground would be to kill electricity when it gets wet, so I have no clue
check the connections on the fender mounted regulator. That's the part that's probably getting wet. May just need to disconnect it and give it a healthy douse of dielectric grease.
The wires on those external regulators like to corrode and loose their insulation too... I got a whole charge harness to replace mine with back in the day, it was horrible shape.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
