coil problem ?
    coil problem ?
    I am trying to figure out why my 83 Merc. GM with a 302 will not start. I know it is an electrical problem. Today I pulled the coil to distributor wire. I noticed a bit of white powder on the inside of the coil. Do I need a new coil ?? Thanks
    Could be corrosion, is the coil making spark?
      I don't think it is making spark. I will be replacing the green wire to the coil tomorrow as it looks crimped. The powder on the coil seems odd.
        a voltmeter will tell you everything you need to know about the health of coil. you can also test it to see if it's receiving 12volts with the ignition on.
          they often get a little crusty, but as long as the terminal isn't rotted off, it usually doesn't mean much other than you need to clean it off.
