Yesterday afternoon I realize I did not have turn signal indicators, but do have Emergency Flashers. Relplaced the flasher in the fuse box this morning. No change. Cannot find a fuse box diagram. Did find a 15 amp fuse blown (fuse 5) replaced it. No change. I do have lights. The wipers work, the high beam works. Not sure where else to look without a manual.
The A/C his not cooling much. The clutch does not stay energized for very long, seems less than 30 seconds then cycles. I can jumper the clutch to stay on. It does cool down some but Normal is coller than Max? Any ideas?
Your help is apprecieated.
