OK, I bought the three little roller plugs and installed them into my Ford (original) window motor. Feeding those damn motor bolts thru the drilled out holes in the interior door skin and then guessing where the motor was was tough, with just one person. My son helped me line up the motor holes with the regulator holes and we finally got it installed. Couple of questions for those of you who have replaced or repaired window motors:
1. With the door trim off and just testing the window function up and down, do you notice that when you hold the button in the 'down' position and the window is at its lower most travel, the door bows out slightly? Is this normal? Is there an adjustment to prevent this?
2. I accidentally tightened, not to high torque, but fairly tight, the window motor mounting bolts before testing whether the motor gear and regulator gear were 'meshed'. When I first hit the window switch, I heard a pop and then everything acted normal (window worked well up and down several cycles. Did i hurt anything?
Thanks everyone...
RT
Thanks everyone...
RT
