Bulbs and Instrument Panel lighting questions...
    What gauge lights are supposed to light up (briefly) when you turn your key on, on the 1990 model? The ones I worry about that doen't come on are the brake light and the oil light. But maybe they don't on these models? The other one that doesn't come on is the seat belt one. Also the chime doesn't ring either, though someone may have pulled the connector on the seatbelt system under the seat. The chime may be the same one used for the 'lights left on' chime
    Also, is there a bulb for the light switch itself? Mine does not illuminate when I turn on my interior lights or my headlights. Thinking maybe there should be?
    95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
    96 Buick Roadmaster Limited Wagon, mostly stock
    77 Ford F150, 400M auto, longbed
    98 Suburban LS 5.7L Vortec, stock
    90 Grand Marquis, stock
    194/168 bulbs. my oil/brake lights come on during the normal check....time to replace em!
    don't worry about the chime...it's hateful anyway
    no light on the light switch oddly enough. you mean the knob that gets pulled outward to activate the lights?
      the red oil light should come on and stay on as long as the key is in "run" without the engine running. I think the brake light comes on for a couple seconds, but don't hold me to that. It should come on if you press the parking brake down a bit.
        correctamundo!
          Thanks everyone! There's one that flashes for like half a second, even less: the low fuel light.
            No, I mean isn't there a light right above the knob? I don't think there'd be a light in the knob.
            thx..
              I want to say the bezel around the knob lights up, but the knob itself does not. At least it lights up on a Lincoln if the bulb is good. I really am not sure about the Mercs.
                nah... headlight knobs in GMs and vics are not lit in any way shape or form.
