lights flickering, distance/heat related
    35 bucks? Ouch.
    So were you just not able to obtain a direct-fit regulator?
    The only difference I could see between the old and new regulator (logo aside) was that the connector was two pieces on the new unit. This meant the regulator itself just had flat metal blades, and the pigtail had the female to mate to that. The oem regulator appeared to have a one piece wiring connector, so you could not pull of the female portion and slot it into the new regulator.
      Having a bit of trouble visualizing the trouble, as the stock regulators I've seen just have four flat male terminals that plug into the stock plug. Or were yours like male spade connectors? Just seems inconceivable to me that a replacement regulator wouldn't plug right in without a stupid adapter.
        the new one was as you describe (four flat male terminals) but the original's was either all one piece or perfectly fused together, so that the only way to separate wires from regulator would have been to pull them physically out of the plug. The "plug" and the area with the "terminals" was one piece. no obvious way to remove them.
        That meant that the new regulator had nothing to connect to without buying a new pigtail/connector.
          Oh, so you were unable to get the plug off the old regulator?
            it appeared to be designed so that there was no plug, per se. where you inserted the wires was integral to the regulator. I'll try and get a picture later, but in essence there wasn't any way I could figure to remove the old regulator beside cutting wires, even if that wasn't going to be done anyway.
              hm, those wires should be on a big common plastic plug. They aren't hard-wired in. Sounds like the plug had gotten stuck, or maybe in the past it crumbled and someone just shoved the individual wires onto the terminals.
                I'm guessing it overheated or something and fused. Maybe even someone snapped off whatever retainer type things held them together, and then it melted enough to fuse. it looks basically like a seamless version of the new stuff.
                Whatever though, it's gone and not garnering weird looks at traffic lights anymore. Thank y'all for leading me on the right path.
