Getting ready to drop in my electric fan.
I had it and a spare battery, well, a large jump box, on the bench and wanted to know which was high speed and which was low.
I figure that it'll draw however much current it needs, that's how electricity works ya know. Fuses aren't necessary unless something's shorting.
Well, I hooked the green wire to the negative clamp, and touched the red positive clamp to one of the two black leads. Fan turns on. Seems like it moves a lot of air, maybe this is the high speed?
Move it over to the other black. Uhhh... the fan does not move, and smoke starts coming out of the back, particularly right past the harness.
Is there an internal short in the motor, time to go back to the junkyard?
Or was there supposed to be a fuse or anything else?? I'm thinking the former though, just want to make sure it wasn't anything wrong with hooking the fan directly to a battery that did anything.
Taurus fans are also 2 speed and just as good as the mark viii ones?
