I don't know if the word atomized is used correctly there, gaseous/vapor...you know what I mean.
bad FPR symptoms?
bad air or coolant temperature sensor can cause that. Might want to wander over to fordfuelinjection.com and see what the sensor should read for a given temperature, then confirm it actually reads that with your meter.86 Lincoln Town Car (Galactica).
Will do. Both of those sensors are only a couple of months old but that doesn't mean much.sigpic
I have not had the time (or clear skies) to break out the multimeter and test the sensors but I'm leaning in that direction...the jumpy idle which went away when I changed the ECT/ACT sensors is creeping back in, ever so slightly.
Replacing sensors that are only a few months old is fucking ridiculous.sigpic
the place where you get on the ferry.
also, these:
