bad FPR symptoms?
    I don't know if the word atomized is used correctly there, gaseous/vapor...you know what I mean.
      bad air or coolant temperature sensor can cause that. Might want to wander over to fordfuelinjection.com and see what the sensor should read for a given temperature, then confirm it actually reads that with your meter.
        Will do. Both of those sensors are only a couple of months old but that doesn't mean much.
          I have not had the time (or clear skies) to break out the multimeter and test the sensors but I'm leaning in that direction...the jumpy idle which went away when I changed the ECT/ACT sensors is creeping back in, ever so slightly.
          Replacing sensors that are only a few months old is fucking ridiculous.
            what are marine terminals?
              the place where you get on the ferry.
              also, these:
                Did you ever replace that FPR?
