Eventually I'll have the entire fuel system replaced but I'm starting with the pump. Mine whines like no fuel pump I've ever heard before....it's sounded the same for about two years now and hasn't given me any problems, but if I'm redoing the whole system I might as well start at the source.
stupid question time:
Can it be done with the tank in place?
What else should I replace besides the pump itself? Does the wiring for the pump run externally for any considerable length that should be replaced due to age/corrosion/etc?
What lph is the stock Panther pump? I believe Fox pumps are interchangeable but I want to make sure I'm right in thinking that. Is there a downside to having a pump "too big"? Or is that like having too wide an exhaust pipe?
