Hi!
I'm installing the sunpro triple gauge (oil pressure, temperature, and voltage), and also a tachometer.
First question:
The temperature sensor has a 1/4 NPT thread on the end. In fact, I'm not sure that there are ANY threaded entrances to the water jacket, only plugs to oil jackets? Is this meant to go into oil, and the idea is that oil temperature and coolant temperature should be pretty darn close?
Second. The oil pressure gauge is mechanical --seems there's no triple gauge option with electrical, and I've bought and paid for the mechanical now anyway-- but I was only later advised by a friend that a pressurized line into the dash is not the best of ideas.
I plan to zip tie it away from the anything hot or sharp, of course, and I might consider buying that steel conduit to protect it?
Any advice on whether you've heard of these lines coming off under pressure and leaking (I'm not quite clear on how the little connections are supposed to keep that line firm!)
Third. The oil gauge isn't the only bit being run through the firewall, I have the other three gauges too. When I did my audio work, I forced a stiff wire through an existing hole. That ain't going to work anymore: these are small wires, delicate wires, and they just won't fit: I'll be punching a fresh hole in the firewall. Just get a quality holesaw bit or a friggin giant 3/4" drill bit with a 3/8" shank (if such exists!) and punch through where it seems to be safe? How do I go about sealing it up when I'm done?
I'm thinking about a short 2" of pvc pipe, sharp edges cleaned up, run my wires, and pump it full of silicone. But if ever there's a short, or god forbid the oil line bursts, that'll be kinda nonserviceable. And seems half-assed and sloppy besides.
Other suggestions for a cleaner and more responsible way to run wires through the firewall?
Four. The relay that connects to the autolights when it gets dark, and turns on the dash lights too, is that easy to get to? I'll consult a wiring diagram. But it would be great if I can have my extra gauges turn on, too, when it gets dark.
Five. This is a part of my engine overhaul. Right now my car is occupying a bay at the school shop, and the sooner I get it out of there, the less likely I'll be to piss off instructors (they're tolerant so far), and the sooner I can give my father his spare car back. I want to install all of these gauges, and I want to do my heater core, and maybe even my multi-switch (got a new one; old cancelcam beginning to wear). These could all take some time, and can be done at home without a lift.
Is there a small amount of trim say around the steering shaft that I can remove, drill through, run my wires through and just leave the gauges hanging there on the floor until such time as I can bring the car home and take the dash apart and install them properly?
Or am I going to want the dash apart before I think of where I'm running my wires to?
First question:
