'89 tripminder to '85 car installation
    ok. Good. if you have the pigtail, it'll make it so much easier to wire this in.
      there is not pigtale in my car. i disconnect the ECM connector, but didn't know how to count pins on ECM module to find a pin #34
      '85 Colony Park LS
        Might be some more info here: http://www.grandmarq.net/vb/showthre...adding-ECM-pin)
        I attached a pic with the pin order on these ECM's. Just look at the shape of the outline of the plug to orient it the right way.
          thanks a lot for the pic. i saw your topic a long time before my tripminder install. and maybe you can load other pins description? it's a very interesting info
          '85 Colony Park LS
            i disassemble the ECM connector and see the strange thing - there is a wire on pin #34 but it's not a blue/purple wire. the photo is not good but we can see a connector on pin
            or i will turn the ECM connector to 180?
            '85 Colony Park LS
              Need to turn the connector 180. Best way to get it oriented correctly is to look at the gray plastic tabs on either side of your fingers in that pic. One is closer to the edge of the plug than the other. In the diagram those tabs are under pin 42 and 60. If there are any other specific diagrams you need let me know, and I'll see if any of my books have them.
                thanx for your answer.
                it's looks to be good to see the other pins from your book. it's a very important info to know how it works
                '85 Colony Park LS
                  last weekend i've installed this tripminder to my car. works fine. thanks to all
                  '85 Colony Park LS
                    That's good to hear! What are you averaging?
                      my average is 23-30 liters on 100 km.
                      '85 Colony Park LS
                        or 6-8 gallons for 62 miles for those of us who don't use easily converted units.
                        or about 8-10 mpg.
                        yeah... that kinda sucks.
                          i decide to repair this
                          '85 Colony Park LS
