actually its not just 12v. When you charge a coil and discharge it, the discharge voltage is significantly higher than 12v. I've gotten lit up more than once by relay coils. Starter relays are diode protected to discharge that voltage to ground so you won't get shocked but it is very possible to light up your life with a 12vdc circuit. It won't kill you but it'll definitely give you a tickle.
Starter Solenoid
well installed the new one and it seems to be fine now reads at 190 to 195 degrees. guess it was time for a new one. no leaking i used castle silicone gasket bead sealer. dries quickly and works good.
Originally posted by marquisman View Postfail safe= FAIL! iv had nothing but issues with them stupid T-stats. iv replaced a few in my own and friends cars cause they stick open. i replaced 3 of them in my buddies ranger. one little burn out, then she is stuck open and running cold the next day. never had an issue when replaced with a motorcraft one. thats why i use alot of motorcraft stuff that is still avail.Last edited by 1987cp; 03-11-2011, 12:30 AM.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostUm, isn't that the point? "Fail safe" means that something is designed to fail in a way that won't wreck your stuff ......... I'm given to understand that sort of design consideration gets a lot of attention in applications where the stuff it's protecting costs a penny or two more than a worn-out Ranger engine.
If you say so. I still see that as less of a problem than overheating, and I'll notice immediately when the temp needle fails to climb to 180. Possibly the average car owner would rather have their engine overheat (triggering the factory engine warning light, assuming they don't ignore it) than notice that they have no heat?
Granted, my car that has a FailSafe brand thermostat also has an electric fan, so it'll stay a reasonable temperature even if the thermostat were stuck open ....2012 Mazda5 Touring | Finally working on the LTD again!
ever since i put the new thermostat in i have gotten much better heat coming into the cabin when i have my heat on.
Cold engines make for excessive wear too. The thermostat is there for more than interior comfort and EFI happiness. The motor wears least and burns most efficiently between 190 and 200 degrees coolant temperature. Funny enough, the stock thermostat is a 192 or 195.86 Lincoln Town Car (Galactica).
exactly. my point, stick with the regular motorcraft part.
Originally posted by marquisman View Postthis all took place in january. the thing is, the gauge never passed the mid mark for temp. i could understand if your temp is close to the red hot mark. but mid? come on, a T-stat should not stick open at that point. it sucks driving a vehicle running cold in bellow zero weather.
Ever run a carb on a car with no thermostat? They run like crap. Carb icing sucks, and being stuck in perpetual semi-choke mode is also annoying. Older Fords with the heater hose that clips to the choke thermostat will do that. EFI motors will run smooth with no thermostat in stupidly cold weather, but they run rich and waste fuel while doing it. You don't get proper efficiency out of a carb on a frigid motor either so its really nothing to do with making the system happy.86 Lincoln Town Car (Galactica).
Nope, never run anything with no thermostat and never had a thermostat fail. Not really sure how or why a thermostat would fail, unless it's a lemon or in an unimaginably severe case of neglect. :shrugs:
Shouldn't an electric-fan car (my new point of reference!) get up to temperature just regardless, except if the ambient air really is that frigid? (I've noticed mine running the fan a fair amount, even with stupid-cold temperatures, so I assume with no thermostat it would operate the same except for slower warmups?)2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostNope, never run anything with no thermostat and never had a thermostat fail. Not really sure how or why a thermostat would fail, unless it's a lemon or in an unimaginably severe case of neglect. :shrugs:
And in response to the warm up times with a stuck open thermostat with an electronic cooling fan...
!995 Ford Mustang, 5.0, with the stock electric cooling fans. The car had one of those failsafe thermostats, and the thing never got warm. Fans obviously never came on because the temperature of the coolant never increased. He drove it for half a year like that. The car was a mega pig on gas, and it had 2.73s in it. He averaged 15 highway... Switched it for a 195 stant thermostat. Within 5-10 minutes the engine warmed up, and the cooling fans came on. He drove it for a few weeks and noted that his mileage had increased by 6 mpg on the highway.
