problem fixed. i pulled the terminal off the wires and they were all corroded cleaned them and fired up. now my thermostat i believe shit the bed. i have full coolant and no leaks and my car was drivin at 220 degrees. i stopped as soon as i noticed it. fixing tommorow.
Starter Solenoid
Originally posted by marquisman View Postlol insulated handle...cause your messing with like...240 household current! lolOwner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
yeah...it's great for you. my bad.
I'm really trying to figure out what was wrong with trying to warn someone against holding bare metal in their hand while they completed a circuit with it.Last edited by 1990LTD; 03-09-2011, 12:52 AM.sigpic
and FWIW I do that every time it rains, it's become a bit of a neighborhood ritual. The cops know me by name now.sigpic
If we were talking about household current, it would be a valid warning. 12v in a car, is about as dangerous as putting batteries in a flashlight.
One exception. It's a bad idea to short out a 500+ amp battery, but that has more to do with burning yourself (and your wiring harness) than any sort of shock hazard.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Usta be an older guy telling a kid 'here, hold this' and passing a plug wire before hitting the key was a right of passage
I've heard that new high powered ignitions can be dangerous though.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
rofl "hey man, im gonna put these batteries in the flashlight..."
"dont do it man! noooooo!" lol
Originally posted by MattsGrandMarquis View Postproblem fixed. i pulled the terminal off the wires and they were all corroded cleaned them and fired up. now my thermostat i believe shit the bed. i have full coolant and no leaks and my car was drivin at 220 degrees. i stopped as soon as i noticed it. fixing tommorow.2012 Mazda5 Touring | Finally working on the LTD again!
well i bought a new thermostat today. the brand is fail safe and is made in isreal and has a lifetime warranty. i went to put it on and overtightened the thermo housing bolts and cracked the hosuing so i got anew one i installed it with the gasket and everything nice and snugged and it leaks antifreeze out from the housing do i need to put some silicone gasket on the housing to seal the leaks. hopefully my car isnt destroyed from running the engine for 5 minutes at 220 Degrees.
I always use RTV and no gaskets on stock-type water necks, and try to let them sit and cure at least overnight before filling with coolant. O-ring necks are also nice, but the O-rings need to be replaced every so often and are worthless if the mating surface isn't flat.
I saw a thread elsewhere with some tips and tricks for water neck installation .... if I dig it up, I'll have to post up some of what I read.2012 Mazda5 Touring | Finally working on the LTD again!
unless you bought one of those rubber gaskets that specifically doesn't require goop... you'll need goop.
fail safe= FAIL! iv had nothing but issues with them stupid T-stats. iv replaced a few in my own and friends cars cause they stick open. i replaced 3 of them in my buddies ranger. one little burn out, then she is stuck open and running cold the next day. never had an issue when replaced with a motorcraft one. thats why i use alot of motorcraft stuff that is still avail.
Originally posted by MattsGrandMarquis View Post.. i went to put it on and overtightened the thermo housing bolts and cracked the hosuing ...
I'd say cast iron block + cast iron heads = it's probably OK. Good luck.
Put goop on the compressed paper gasket. Then install and tighten carefully. You won't have to wait if you do this. Black RTV alone works well, but then you gotta wait 24 hours before filling the cooling system.Originally posted by gadget73There is nothing more permanent than a temporary fix.
5 mins @ 220* isn't going to hurt anything.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
