Box/Aero Dash interchange
    Are Aero any dash parts compatible with my 91 or can the entire dash be swapped over?
    I know that you can add the cupholders to a '90 from an aero.
    You could probably swap the dash over.
    Keep in mind though, the climate controls are on the bottom of the dash. I don't think anyone has ever tried to though.
      The steering column/wheel and the multifunction switch are the same 90-94, that's the only help I can give.
        Yeah that too. I've been contemplating swapping a aero vic dash cluster into an aero box. I think they might fit, no telling for sure though.
          I found out by physically checking that some dash parts are common 95-02. I may snag an entire 97 dash and see if it fits in my 91.
            Do it!!! If you can, it's another first! Are you gonna hook up everything?
              I started to pull the '97 dash today and ran out of time. I pulled the speedo cluster just so no one else gets to it first. I looked at a couple of 92-94 dashes and decided I definitely do not want one of them. I want the dials for HVAC control and the round guages. This is going to be ALOT of work, but if it can be done it will be a huge improvement. I noticed definite differences in comparing the the 92-94 and the 97 tail lights and panel and the grills. If this ends up being too much work, I will sell my 91 and do a 351W swap into a 95-97, preferrably a 97 P71.
                Originally posted by mercracer View Post
                i will sell my 91 and do a 351w swap into a 95-97, preferrably a 97 p71.
                ooooh!!!
